Early 1928 oil pan
joesplas
Is it possible to change a oil pan out to a newer pan? I have a 1928 oil pan with the bottom clean out and it is in rough shape. I want to install a oil pan from a 1930 engine. Everything looks as if it will fit ok but just in case I am missing seeing something I thought I would ask.
Thank you
I may be wrong I think the only major difference is the inside divider tray. I though that the opening for the oil pump was made bigger, because Henry made it so you could put a shield of the oil pump. Don't quote me on this.
