Hi All! New member and new owner of an early '28 Roadster - Apr/May manufacture I believe. E-brake lever mounted on left frame and segmented brake cross shaft that does not utilize shaft bushings on the outer ends. No independent e-brake shoes.
I would like to keep the original setup and I have everything I need with the exception of the frame brackets that restrain the outboard part of the cross shafts. I ordered current brackets and shaft bushings but clearly these are not made for my car as I had to 'spring' the cross shafts to install and pedal operation is overly stiff (although brakes work reasonably well).
My first desire is to try and obtain two sets of these frame brackets but I understand that this might not be possible. Next best thing would be to obtain some good pics of what these brackets looked like so I could attempt modifying the modern ones to suit.
If anyone can assist it would be much appreciated. Email is jdosenbe@telus.net
Pic of my new ride attached below. Many thanks! Jack
