ok heres where im at all new plugs and wires and cap and condensor new coil new points points set is inbetween 0.14- 0.16 like i have read about and u pour little gas doen the carb and it hits and like it back fires threw the exhaust u can feel the heat where it burnt up the raw gas . and the exhaust pipes steam . could this thing have a stuck valve in it ??? causing that or maybe a stuck ring ??? cause its not back firing threw the carb as it should if it was out of time or etc . i rechecked the firing order made sure that no wires was crossed and etc . or maybe the carb aint doing its job ???
