e28 Model A Parts
mmindling
Watertown
Ohio
Hi, this is Martin in Ohio. My car is *A 11739*, January, 1928. Here's a short list of some e28 parts that I'm looking for:
*Lower Light Switch housing with knurled band A11655
*Splash Pan Bolts with holes for cotter pins
*Junction Box Cover - gen. 2, with Ford script about 1" below top.
*Head Nuts -early type, 3/8" tall.
*Battery Cable Support Bracket - left body rail, held by first body bolt.
*Battery Hold Down Bracket - square, for top of battery
*Floor Mat Studs with wood-screw bottom end
*Stoplight Switch - flat, no ribs.
*Key Blanks - Ford script
*Light Switch - marked "on" "off"
Thanks for all help. I will respond to all messages.
Regards,
Martin Mindling mmindling@aol.com
I have a early trans with housing, pedals & linkages and a complete clutch *** and no shift tower. Also have two five bearing cams. The trans & clutch has very low miles--The flywheel is there valso and shows absolutely no wear on the clutch splines---they are the hardest part to find, usable! binkbee@insightbb.com
