Steve Plucker
What does the small spring-like plunger do on the other side of the bakalite terminal? I thought by pressing this would release the terminals??? withouthaving to pull rard on them???
Pluck
Pluck
Pluck
There is no release for the spring loaded bullet sockets for the wire terminals. You just pull to overcome the spring pressure on the bullet shaped plunger that holds the terminals.
On the side of the socket is a spring loaded plunger that locks the socket assembly into the taillight housing. You have to push in on that plunger then rotate the socket to disengage the brass strap from the terminal groove, then pull the socket out. Kroil helps for this.
