29restorod
I am installing hydraulic brakes on my 29 coupe,and I may have found a problem with my hand brake. On the bottom of the handle below the pivot point,there are two holes. One has the cleves,and the pawl attached with the same cleves pin. The other hole is unused. Shouldn't the cleves be on the bottom hole? I will be using the center arm on the E-brake cross shaft for my E-brake cable equlizer.
