Oh, what a dummy! Don't know if you're still out there or not, but if you are, forget drilling jets: just turn the enrichment screw (GAV) until you get the mixture adjusted for the E85! I'll bet a doughnut that's why Henry was able to run ethanol in the 1920s without any carburetor tricks. Ain't Model As grand?![]()
Is the GAV effective throughout the entire range of throttle opening? I thought it was only effective at low engine speeds?Oh, what a dummy! Don't know if you're still out there or not, but if you are, forget drilling jets: just turn the enrichment screw (GAV) until you get the mixture adjusted for the E85! ...
... Well, here's the nerdy stuff: Ethanol (EtOH) contains just under 35wt% oxygen and there are no Btus in oxygen. Btus = range or fuel economy and that's why you get poorer fuel economy (about 35%) with neat EtOH. However, the latent heat of vaporization of ethanol is much greater than an all-hydrocarbon gasoline (0.93 MJ/kg vs. 0.18 MJ/kg for the exceptionally nerdy) and so it cools the incoming air charge considerably (note the cooling sensation when you put alcohol on your skin). This provides a denser charge to the cylinder and allows the engine to make more power at any given throttle setting, or for any given throttle setting it makes more power; i.e. you go 50 mph with less throttle because of the denser air. This does not cancel out the lack of heat energy, but it helps some (Cessna recently did work using an ether and produced some nice data to support this). Racers use EtOH but prefer methanol (MeOH) because its latent heat of vaporization is the highest of the alcohols (1.17 MJ/kg), even though it contains 50% oxygen (really bad fuel economy) and is quite corrosive. ...![]()
thoughts on using E-85 with the weber carb. i am trying just for the fun of it, seems i need to"hog" out the jets a little. any idea how much?
Thanks for the clarification, Steve. It would seem, then, that E85 users could take advantage of the cooling effect of the ethanol, whereas those of us with 10% EtOH fuels can't. I'm aware there's a 1 psi RVP EPA waiver for ethanol fuels, but I thought it was because of the ethanol only, not the effect ethanol has on the bulk gasoline. What's your take on that?
