dwell for a '56 292
ahshoe
Does anyone know the what the dwell should be for the points for a '56 Ford 292 motor? I need the dwell both in inches and degrees.
Also what is the timing supposed to be? and at what RPM do you check the timing? Lastly is the timing markers on the front balancer like later Ford vehicles?
Point gap .015
Dwell 26*-28*
Timing 3* std trans
6* auto
Set timing at idle
Timing marks on crank damper pulley. (balancer)
