Duel master
STEVE1103
Any info will help, lost the instruction on the installation of a duel master cylinder for my 55 F100, have the kit, duel master, no booster, 2 diferent push rods, going to keep it all drum, reuse the brake pedal. Thanks
If the instructions are no longer available from the kit's origin, what do you need to know?
The old master wasn't there when I got the truck, how does the brake pedal, activate the master cylinder, think some of it is missing. Thanks
Thanks JeffB2, I have done one on my 53 Merc, and 60 Chevy, they had swing pedals, having trouble with the truck with the pedal onto the floor.
Thanks guys, figured it out, will try puting it on soon, had to change the rear wheel cylinders today, might change the the rubber hose and line to the master next, will need to check the fronts seeing how bad the rears were. Truck has been in my garage for about 4 years now, think I need to install a dehumitifer!! Have a great weekend!!
