scicala
"The easiest way out of it is with a 57/59 - 60/ Y-BLOCK dist. This will also require a later style carb (H4000 does not have correct vacuum signal) or a CARTER WCFB of the period (so that you can retain your present intake) to deliver a ported vacuum signal for the advance."
"A '57+ distributor is the better dist but needs a vac signal from a '57+ carb to advance the timing correctly. I've been told the teapot carbs can be modified to work with a '57+ dist."
You can change the distributor to a '57 and later design and still keep the original Teapot Holley 4 barrel carb. The teapot, or any Loadomatic style carb can easily be converted to ported manifold vacuum signal to the distributor.
Just another way to go. Saves money too.
Sal
Sal
