joe in ma.
I am instaling a dual reservoir master cylinder in my 41 pu having trouble finding part number for bolt on top master all I can find are spring top masters do not think I have enough clearance for it under the floor
Wish I had found that when I did mine LOL
What car? I have a 35 2 door slant back and a twin pot mounted in a relatively normal place above the steering column. Sorry, I can't post pics.
Yup, that is a much-needed modification for those seeking to run a dual M/C. It's kind of unfortunate that they built it with a 1" diameter bore, as the originals (as far as I know) are 1-1/16" diameter bore. This means that the stroke of the pedal will need to be longer to displace an equal volume of brake fluid to match the original M/C. This could introduce issues with possibly running out of available pedal travel, and especially so if one circuit of the cylinder develops a leak.
Coop
The movement increase is about 3/8" at the master when comparing the larger bore master of 1 1/16" and the greater amount of piston movement with the smaller bore master of 1 inch. (0.866" piston travel in the 1 1/16" bore to move 1 cubic inch of brake fluid vs 1.27" piston travel in the 1" bore to move 1 cubic inch of brake fluid)
With that extra 3/8" AND the pedal ratio, you might very well bottom the brake pedal into the floorboard on some vehicles/applications.
It wasn't a problem on my '48 truck but it just underscores that you wouldn't know the true story unless you did the math.
The math that I am seeing here doesn't tell the ENTIRE story. If you subtract 0.866" from 1.27", that leaves an ADDITIONAL distance of 0.404" that the PISTON must travel. That is not the main concern. You must also take pedal travel into account. This means that the pedal pad (the part that your foot pushes on) must travel a GREATER distance which is dependent on the pedal ratio. Pedal ratio involves the difference in the distance of the pushrod pivot pin vs. the distance that the pedal pad is from the pedal's pivot centerline. If the pedal footpad is five (or more) times farther from the pedal pivot point, the pedal RATIO is 5:1. That means that the pedal PAD must be able to travel FIVE TIMES the ADDITIONAL DISTANCE that the piston must travel. In this case, we're talking about an additional 2.02" PEDAL TRAVEL.
BEWARE.....as this does NOT INCLUDE any additional pedal travel necessary as I referenced ABOVE because of a leak in one side of the system. All that I am suggesting here is that it should be wise to induce a "test leak" in each side of your newly-plumbed brake system to insure that you still have full-stroke-pedal capabilities should a leak develop in either side of your system. Also beware that "full stroke" means WITHOUT THE M/C BOTTOMING-OUT. The M/C should NOT bottom-out.
Coop
Well if you are going to use a 1" dual master on the stock pedal assembly operating Lockheed brakes, you better see how it does with a simulated failures of either the front or rear brakes; then consider how it would do if the brakes were worn some and not recently adjusted.
Mart's 1-1/16" E250 master cylinder is a good alternative; but is physically larger and will require a bulge in the floorboard cover. In my case I made a wood die and pressed a cover in my press.
