Yep, got a "67 drum/drum Mustang and it works fine with early Ford brakes.
I just have a residual in each line, no proportioning needed.any other valves needed? Proportioning, etc? Or is it just a line out to the front and one to the rear with residual valves in each line?
At the risk of hijacking this thread, but same subject, is there a dual master set- up available for a 1950 shoebox? Thanks,
Howard
Same here,need residual valves,but works good!
Also note the port nearest the operating rod is for front brakes.
John
Originally Posted by ChiefRocka![]()
The REAR PORT, closest to the PUSHROD is the main, or "primary" chamber.
This port is for the FRONT brakes....
The FRONT PORT, furthest from the PUSHROD is the secondary chamber....supplying the REAR brakes.......QUOTE]
Not always. There are some vehicles that have the rears plumbed to the primary piston/chamber. The larger chamber, if obvious, always goes to the fronts on cars and light trucks, whether primary or secondary.
Thanks Bob, I wondered if anyone would bother casting a dual unit, that strange, for the short '49-'51 application. I'll look into the sources you suggested.
Howard
