Dual carb linkage
oldgrayman
I have a ‘46 PU with a 59AB engine and a single 2-bbl carb. For no other reason than to add to the looks of the engine, I want to switch to a dual carb setup. There are tons of pictures online showing the driver’s side linkage, but I want to retain the original hard throttle line and control the carbs from the passenger’s side. Is this possible? Would I still be able to use the hard line to control the chokes? Thanks!
I did a Google search and found this on the HAMB.
It looks like you can use the stock linkage for your throttle and choke.
Look closely at the picture. You will notice that you only use ONE choke just remove the other one.
Get in touch with Charley Ny he will fix up with your project.
It looks like the choke rod has been shortened, which is pretty easy to do. Also, only one of the chokes is hooked up which is really all you need.
What has been said above X2. I have 2 cars with dual carbs, my avatar has 97s, my 5w has 81s. I only use 1 choke which is plenty for each car.
For everyday driving, a "progressive" throttle linkage is usually best. Flathead engines are touchy about the carb volume, particularly at low speeds.
This may be true for a "Regular" manifold (one with the carbs biased towards the rear), but I've never heard of anyone doing this successfully with a "Super" manifold (one where the carbs are placed directly over the two sets of four intake ports). The example shown is somewhere between a "Regular" and a "Super", so I am not sure how it would run with progressive. I would expect it to be worse than a regular, but perhaps a little better than a "Super". I've never had one of those, so I don't really know, but I expect it to have fuel distribution problems.
On a regular, the primary is the front carb, with the rear carb coming in later.
biggest problem I have had is getting the jet size that works best. I have done several of these using the adjustable main jets from speedway and have been impressed as to how easy it is the set up the carbs correctly
My avatar 32 has an old Edelbrock Super with straight linkage, no progressive, my 5w has an old Eddie Meyer intake with same kind of linkage, both carbs coming in at same time. No drivability problems at all. The 97s are jetted down, the 81s are fine as is.
I believe the progressive linkage is most useful on tri power setups.
I ran straight linkage on dual, fully functioning 94's. I got jets and power valves from CharlieNY. He had me put one of his PV plugs in the front carb. Ran great, looked cool, and made folks smile. Chap
