I just replaced my single action fuel pump on my 52 Vic with a dual action pump that was on the car when I bought it. The reason I put the dual pump on was because my wipers were not working well at all. Also, I put a PCV valve on which was drawing vacuum from the carb base. I now realize that there are two vacuum ports on the base of the pump. However, the left port has a metal tube fitting for a vacuum hose but the right one does not. There is just an opening on the right side. I know that one of these ports is an inlet and the other is an outlet. The pump will not operate the wipers unless both ports are in operation. How could I add a tube to the empty port since there is no tube extension on the right port? Also an explanation of the routing of the two ports would be helpful. Thank you for time and expertise!
