In my early days learning about Model A's, I neglected to put the keys back in the axles after doing something inside the rear drums. After tightening the outer nuts, I tried to drive the car forwards. It wouldn't budge in gear, forward or reverse. I could hear the transmission working in 1st gear and hear scraping revolving sounds come from the rear. But there was no movement. I happened to glance at the newspaper on the floor where I had lain the parts removed while taking off the drums. There were the two axle keys, greasy and camouflaged on top of a black and white photo in the paper. That's why I had overlooked them. The axles had been spinning inside the hubs, which is the noise I heard coming from the rear. Going through the motions again, I replaced the keys and the car moved as it is supposed to. Lesson learned: Don't forget to re-install the hub keys!
Perhaps the outer nuts were not tight enough to drive the drums far enough up the axle, but I should think the keys ARE necessary to turn the hubs without the axles slipping inside them, as happened to me.
Marshall
