psimet Senior Member May 11, 2021 #21 Picked up a deep well 1/2" socket - 1/4" drive, wobble/universal, and a 6" extension from Home Depot the other day and was able to get on top of every bolt on the pan after removing the inspection plate. It fit fine.
Dave in MN Well-known member May 12, 2021 #22 I use a 1/4" cordless impact driver with a 1/2" nut driver with 6" shank. I use it for off and on... Good Day!
R rfequity Junior Member Jun 22, 2021 #24 What kind of gasket do most use when they reinstall the pan? Also, is there something to do to some "rear seal" when you are doing this job?
1 1929 Well-known member Jun 22, 2021 #25 I also had to grind the socket to get a good fit, it is now my oil pan only socket.
