David in San Antonio
Driver’s Door Mechanism and Window - Slant
Slant windshield Fordor, driver’s door.
Is there a method that makes this easier?
I’m replacing the door mechanism and it’s a bear to locate in place inside the door (sandwiched between the outer and inner door metal, and with the window glass). The nuts and lock washers have to be suspended in space while running the bolts through the inner door while keeping the mechanism aligned with the holes. You cannot see behind the inner door metal, and it seems to require at least three hands, but there’s no room for human hands let alone a hand holding a wrench. Has anyone figured out a method to make this easier?
And less importantly, how was this done at the factory?
(I got the replacement mechanism from Steve Becker at Bert’s. He said all the models prior to the slant windshield were much simpler.)
I managed to crack the window while removing the old mechanism, too.
There’s got to be a better way. I hope.
