rheltzel
My '35 (stock drivetrain) has developed a "ticking" noise when I let the throttle off. It's not the engine (not RPM sensitive and makes it even if the engine is shut off). Not a bearing noise. Makes the same noise in all three forward gears (although most prominent in 2nd and 3rd). Obviously thrust related. Nothing visually obvious. Started all of a sudden while going down the freeway. Doesn't happen when car is first started in morning; starts after about a mile and then constant whenever coasting.
I'm thinking the universal joint. I suppose it could be the output shaft of the transmission, although it was recently rebuilt.
Any ideas?
Any ideas?
