[/IMG]![]()
I get industrial heat shrink made for electrical connections, it is about 1/8" thick, strong and impervious to gas, oil and solvents and just fits over the shaft and rivets. Heat with heat gun until glue is bubbling out each end and you are done. The ends cannot come out even if the pin breaks it stays in place and can still prevent the shaft from moving. This is a NOS driveshaft which I put Glyptol on and came as an assembly with new collar installed with the rear pin just started.
Electrical Supply places have this 3M ITCSN-1500-12 BLACK. 12 is 12" and is enough to do 3 rear ends.
This stuff is tough as you will see when you cut it. I posted another picture in my MISC folder
Spring is between u-joint and speedogear pushing driveshaft down towards rearend.
[/IMG]![]()
Thanks, I didn't think regular heat shrink would work even if they made it big enough.
If you ever needed to remove it, probably would come off pretty easily with a sanding disk or grinder.
Wow Dick, 4" you worked with some pretty bad-*** wires!
Thanks for your kind words. Mike
*** said:Shrink wrapping a drive train coupler is hilarious for a torque tube. I wouldn't want that floating around 10 yrs from now.
That highvoltage shrink sleeve is nothing like the heatshrink tubing you can buy in the normal store...a knife doesn´t cut it without a serious amount of force involved.
It should withstand someone jumping on a shovel without getting zapped.
Only downside is the pricetag...
Thanks again Deuce for the tip. If anyone would like a piece of this industrial heat shrink and can't find it locally, send me a PM. Just pay the shipping and it's yours.
