coxswain98
I just installed my stock closed driveshaft into the torque tube and rear diff coupler. When I turn the driveshaft, only the passenger side wheel turns. Turning the drivers rear wheel makes the other wheel turn in reverse and turns the driveshaft. Same for the other wheel. Can someone explain this? I know that ‘posi-traction’ makes both wheels turn the same direction when you turn a wheel, but if turning the driveshaft doesn’t turn both wheels, what makes the driver wheel turn?
