The low band will wear really fast if you have a cotton or wood band and the low speed adjustment is so loose it won't lock the drum. If you have kevlar the risk the drum will heat up until it cracks increases even more when slipping the band, but if you're lucky tightening the band is enough. It's best to open the inspection lid to see how much is left of the band(s).
When starting, press down the foot firm to lock the low drum as soon as possible without making any jerks or killing the engine. If you have a medium heavy T and std rear axle gears you don't need much gas for taking off - experiment with less advanced spark and low rpms, you can minimize band wear with your driving technique. Then as soon as the car is rolling, you can increase throttle (and pull down the timing lever if retarded)
The same goes for the reverse, but it's often hard to avoid slipping that one, since it's used for such a short move - not much driving with the reverse fully pressed down usually. Be sure to hold the steering wheel tight if ever going fast in reverse - the steering isn't as stabile as in more modern cars when driving in reverse and may flip..
The brake must be slipping some - but you can minimize it by closing the throttle in time before approaching a stop and only use the brake for the last mphs. Lifting the brake foot at intervals to let in oil is also a good technique, but never get you in a situation where you have to use the brake for long periods - if you go down a steep mountain road where you would have needed low gear to get up, then you should go down in low gear with the throttle closed to keep the speed down. Retarding the spark may increase the engine braking.
With low or reverse you don't need to lift the foot to let in oil - they're supposed to be locked firm when used and doesn't need any oil when in use.
Always keep the emergency brake in good working order and be ready to use it - if needed. A 09-25 may need accessory lined shoes. And grease seals in the rear axle
