drip moulding installation
Cider Mill
I bought a 29 tudor that had no top. I replaced the top wood and installed the top. I had the original drip moulding and base pieces. I nailed the base piece on, but now I don't know how to attache the actual drip moulding. I tried tapping it with a plastic hammer, but no go. Any directions out there somewhere? Any suggestions?
dan the outside gutter just snaps on with a little tap of a hubcap hammer which might have a little more weight behind it than what your using. hook the top of the moulding on first then tap the bottom its actually pretty easy hope this helps
I am trying to install new drip moulding that I have to bend. Any advice is welcome
good luck my first tudor i had to bend the moldings PIA. made a template out of wood and bent the molding around that. but now they sell prebent ones at the suppliers thats the way i would go but you didn't mention your body style
