I had that sickening feeling of seeing water run out of the hole that I was drilling in the side of my block.
One of the studs that holds the exhaust and intake manifolds on had broken off of our '29 RPU. It was flush with the side of the block.
I stripped the side of the motor. Made one attempt at welding a nut on the end of the broken stud with no luck. Because of the size of the bolt and the heat that I'd need, I decided to try and drill out the stud.
I was careful enough with the drill but when I put an "easy out" in the hole and starting trying to work it backwards, the easy out pushed through and into the water jacket and she poured water out of the stud hole.
Not being an expert on the construction of these blocks, is there a repair for this?
