Drake's windshield frame seal 35/36
Thanks for the drain info, my truck was built by Ford Canada, actually is a Two Ton rated with Two Ton stainless logos on the hood in place of the usual plated brass V8 logos. No separate garnish moldings. ..B.
Re: Drake's windshield frame seal 35/36 Drain Holes at each side of W/S
For hooking up the drain holes at each side of the W/S trough, a short stub of copper pipe flared and sealed on each side then connected together with a small plastic tubing (same size as they use for a" breathing apparatus" from an O2 Bottle) or similar , "T"ed together into the Drain hose with another "T" and into the Cowel vent drain , the plastic hose is flexible and won't sag or deteriorate as much as the rubber hose used for the wipers JMO..:)
