Drained the oil from engine and gearbox today, 59ab motor
Gearbox oil was quite thin and looked like it had mud mixed into it!
Poked a finger in motor drain plug and got some nasty grey sludge out. Took the pan off to find nearly 1/4" of gunge in the bottom of the pan. Thinking I should remove the pickup screen as that's fairly low in the pan. If that was restricted would that affect oil pressure?
The oil return pipe (from filter to pan) looks like it's blanked off inside the pan, shouldn't that be open to create a flow of oil?
Ian
Ian
