aandtman, thanks for your reply. I am still looking for a drain panel for my 35 Ford 3w cpe. Please give me a call. 570-956-5911. Tom Z...Tom, are you still looking for a drain panel ???
This mans drain pans are oh so nice !!!1 A huge thanks to him for making these !!!Tom, are you still looking for a drain panel ???
I'm looking for 1935 rear drain panel can anyone help
cell#636 887-1949anytimeI'm looking for 1935 rear drain panel can anyone help
mine to. i was just going to start a thread, thought i better look first. i PMed the fellow, we'll see if he's still doing them. might have to get dirty on this one. mine is still intact, but many holes and small cracks. i thought about fitting a piece of 20 g. in there pressed in to epoxy for a quick fix. summer car.I got a surprise when I took the panels off the rear roll down window. The drain pipe was blocked solid. The bottom of the panel was rotted (rusted) out. Does anybody repop these drain panels? Thank you Tom Z...
nice. somebody getting it done. i'm right behind you, i just got to finish a couple of other things first, but it's coming right up. i haven't even unbolted it yet. the top edge of your old one looks a lot like mine, all mis-shaped. thanks for the photo. it helps others to get started on this repair.Not too bad to do, if it doesn't have to exactly match the original tray. To overcome the limitations of a regular brake, I started the bends on the brake and finished by pressing the piece into a channel to bring the sides up. Not being a sheet metal lay-out guru; I made it square; then trimmed the sides and edges to make it taper to the right.
wow. looks really good with the square corners. i thought about folding over the top edge of the interior side so that it wouldn't get all wavy looking like mine is now. just like 1/2" to keep it stiff. did you paint the inside with something good? i've been having good luck with por-15 to really seal these types of projects, just scuff it real good with some 60 grit for good bite. soon i'll be there too.
