Ficco55merc
Quick question that I couldn’t seem to find a definitive answer to from searching past threads, trying to tighten up steering a little, drag link is where I’m seeing the most movement while under car with someone moving steering wheel back and forth.
My question is how tight is everyone going with plug?
My manual says tighten fully then back off 1 1/2 turns and install cotter pin,
Another manual I saw on a ford trucks forum called for backing off only 1/2 a turn to install cotter pin.
Seems like a lot less slop when I go the 1/2 turn out but don’t wanna cause any premature wear from over tightening plug.
I did rebuild this drag links 5 or 6 years ago and I think I went 1 1/2 turns out and it’s always been a little sloppy. Better after fresh grease
