53 Flathead..I am in the process of installing my draft tube after rebuild. It has been some time since I removed it, but I kept the clamps in place on the tubes. As I am installing the draft tube, it seems very close to the water pump pulley. I flipped the clamp over so the bolt is toward the center of the motor, but the tube still seems very close to the pulley. I can't see any way to change the position since it bolts to the timing cover. I assume that the clearance was always that close, and I just didn't notice it before. Am I on track here, or am I missing something? Thanks. I know the draft tube isn't ideal, but I won't be driving it that much anyway.
Tommy
Tommy
