Typical to have the inner venturi, the outer swells and breaks in half.
You could notch a single venturi to fit the original inner piece, the problem is that the single venturi is smaller I.D. than the double venturi, you will have to open up the entire shape of the single to work properly.
OR you could buy a new double venturi.
