JD 1931
I have rebuilt a few double venture Zeniths and I have one in process now that has a steel choke lever that has a D stamped on it and it has a steel throttle lever that has D on the back with an F inside, the throttle lever is molded the same as the brass and also the choke lever, never saw these before. It has the cap jet the has the orfiest on the under side. ... JD
