FWIW: Just another type that I bought about (7) years ago when they were $14.00 a pair ...... now they are $19.00 a pair.
The ratchet types usually fail at the single shear area of the cast iron teeth protruding from the cast iron bar because of a poor or defective casting ..... many are cast & made from parts in China.
The two (2) pairs I bought shown below are Canadian made by "Larin",
"all" steel, no cast iron, with no possibility of a void in the cantilevered cast iron teeth causing failure.
Anybody familiar with structural steel analysis will be able to immediately see the positive safety factor built into the non-cantilevered all steel Canadian "Larin" Jack Stands.
Larin jack stands are provided with 2, 3, & 4 Ton Models.
Bought these jack stands from FLEET FARM, Oshkosh, WI.
Now, if one likes to take chances, just buy four (4), of the cheaper three (3) legged jack stands from e-bay to use when tightening large bolts under your Model A ..... might help to increase feeling more secure & safe if you have one of those devices advertised like: "HELP, I'VE FALLEN & CAN'T GET UP!"; or better yet, leave a copy of your will on the running board.
Hope this helps a little for one to choose jack stands.
Home / Larin Jack Stands - 2 Ton - 1 Pair
Online Item #: 0000000008082 SKU: 002361384
$19.99
