Door Trim question
Does any one have a source or alternate solution for the clips that hold the trim around the topside of the window on a 36. I called ThirdGen and it sounds like they are made from unobtanium.
I was thinking about just using 3M body and trim tape.
Andy
I just checked the catalogue for Restoration Specialties and it looks like wire clip 1198-CLP is what you may need, and I used them for my 36 Ford 5W Coupe.
They insist that you call them to verify the size you need, and caution that you do not guess at the size. 814-467-9842
Thanks
Gary Tosel
Rubber bumper inserts into the door and the garnish may have been used the rubber inserts are available.
