I did re-adjust the striker plate on my '29 this summer, the wear allowed the door to become slightly ajar. Usually a right turn or maybe a hard bump would do it. Probably replace mine this winter.. the nut plate is secure in the door frame construction on mine (a May '29 build). I just loosened the screws, adjusted the fit/closure, and tightened. So far no problems, good luck.! kb
