Door Stops
JohnB15632
It seems to me that these door stops are a bit ratty.
So, I am thinking that they need to be replaced.
The problem is that I have no idea how to remove old door stops, nor do I know how to install new ones.
Can anyone out there give me a hand?
Thanks,
pull outward, should be a metal clip under them.?depends on year type vehicle also.
Pull outward, but no metal clip under them. They are a rubber block that fits in a open slot. The rubber is molded with a part that fits behind the slot. Use a blunt screwdriver to force new ones in.
OK, I got the old ones out. I need help determining what are the new ones? I see nothing similar on the vendor's websites.
Anyone know the correct vendor and part number?
Thanks
