I hate these cheap aluminum sill plates. I keep catching my shoes on them which makes them stick up more. I'd remove them if there weren't two screw holes there.
Do they make better versions of these or am I the only one getting caught on them?
remove the plate and cut a piece of rubber mat to fit over the sill. use some contact cement to hold it down and you can cover the holes at the same time.
I have the same part and the same problem. I was going to try filing the edge back some but haven't got around to it yet. The aluminum part seems nice enough except for this problem.
