door panels 48 coupe
As suggested first make a pattern of the door and the existing holes. The standard clips to hold the panel are offset. Get a sample clip which will give you the offset and make the holes in the panel using the offset measurement from the clip..
Clamp the panel in place and use a gizmo like this to locate the clip hole; then make the holes in the panel at the correct offset. I try to set them so the panel hangs from the clips.
If you have a friend that's an aircraft mechanic ask him to borrow a hole finder of the same diameter as the hole in the door.
