Mike V. Florida
In October it was written
"To be authentically correct, the primary color (lower body color) would be applied on the body, and the trim color (secondary color) was applied over that. The jambs would be painted in the lower body color and the trim color was applied on the outside area only. The lacquer paint actually "oversprayed" through the door gaps and only wrapped as far as one could see from the exterior when the doors were in the closed position."
What about the inside edges of the door? Were the doors given coat of paint before they were installed then painted with the rest of the car as above?
Now that I think about it what about the gas tank, as the inside had to have color and the cowl welting was also painted was the tank also given a quick coat, assembled, and painted again?
