I have a 47 pickup 1/2 ton and I was wondering if I could put a keyed door lock on the Driver side door like the pass. side door? I'm 76 and it's unhandy sliding across the seat after locking driver door. Any help would be Appreciated. Thanks, David
I assume if you installed a P.S. handle in the D.S. it would operate backwards if you could install it at all without modifying the door skin. also would have to install a P.S. locking latch upside down to make it operate.
Wouldn't the key just turn the other way if you installed the lock right side up?
I think the big problem for me would be cutting a hole in the door for the lock cylinder.
And, you'd need to install the sheet metal sleeve to hold the lock cylinder in place as well as the threaded sleeve to "pin" the lock from rotating within the aforementioned sleeve.
Methinks if someone really wants the '47, they're going to take it. It's simple to enter a new car and bypass nearly all so called security systems. A '47? Child's play.
What's this world coming to? I live 25 miles north of Brainerd, MN, and the only time I lock my car is when I go to the Twin Cities.
