I am at the restoration stage of aligning the doors and hood on my 1930 Model A CCPU.
I have researched the Fordbarn and other Model A Forum archives, as well as many of the resources available to me, including Marco’s “Door Alignment” section in “The Model ‘A’ Barnyard”, Les Andrews “Model A Ford Mechanics Handbook – Volume II”, and THE RESTORER's “How to Restore Your Model A – Volume 2".
After numerous attempts, I now have the firewall hood welting frame perpendicular to the fender apron. As a result the passenger door appears to be close in alignment, with body lines on the cab and on the passenger door about lining up. Not quite so on the driver side, as the door has a rear sag showing, and the body lines on the cab and on the driver door not lining up. See pictures.
At the start of the restoration process, I replaced the frame that came with and was under the cab with an original 1930 frame. Based on the number stamped on the frame that came with the pickup, the frame was a 1929 frame. However, the cab appeared to be a 1930 cab. I had the 1930 frame check for straightness and sagging by having it checked by an auto body shop and myself.
So what is the problem – in order to achieve the current alignment, ie., getting the firewall hood welting frame perpendicular to the fender apron, I had to install additional rubber shims/spacers under the cowl. I have about 9/16” of rubber shims/spacers under the cowl, and only one(1) body block rubber pad under the rear of the cab. See pictures. This alignment creates a large gap between the front of the cab and the running board sections that sets on the frame, and a corresponding gap between the bottom of the hood and the fender shelf. See pictures. As a result, I am not able to latch the rear hood latches.
I am unable to get the radiator shell perpendicular to the fender apron. I have adjusted the radiator support rods to obtain the 31-3/8” measurement from the base of the cowl band at the front edge of the cowl band to the base of the radiator shell at the hood edge.
Finally, I have installed an additional radiator mounting pad under each side of the radiator.
I believe the hood alignment to the cowl and radiator shell is getting close to being correct. However, the gap spacing between the bottom of the hood sides and the fender apron is not acceptable to me. So, I am hoping to get some ideas as to what I should do next or undo.
What is the first thing a person should do when aligning the hood and doors? If I understand correctly, is getting the firewall welting frame perpendicular to the fender apron one of the first priorities? What then would the next step(s) to take. I just do not know where to go from here. I really would like to reduce the body shimming to no less than 3/16", and no more than 3/8" at any of the body bolts. I am aware this process requires understanding, finesse and patience. I would apprciate any comments/suggestions to assist me.
