Door hinge screws
27TV8
Hello. Anyone know were I can get a set of door hinge screws for an F1.
They are countersunk 1/4 fine thread. Straight or philips. Any one repro them? I am not sure of the counter sink taper.
Thanks
They are actually 5/16-24. The only way to get the original look of oval head Phillips is to go stainless I have not found them in steel. I think it is sac vintage ford that has steel flathead Phillips listed under 53-55 truck latch screws. I found one of the repro places had the screw and countersunk star washer available together as a set. For some reason they are not described anywhere for 48-52 trucks.
Our research has shown that a 5/16-24 phillips head screw and external tooth lock washer were used to attach the door hinges on this vintage Ford vehicle. While oval head were used on the commercials, flat head were used on the passenger cars. Trust me, these items are readily available.;)
Roy Nacewicz
Roy Nacewicz probably has them as he has lots of hard to find nuts and bolts for Fords, etc. Google his website and give him a call.
Try you local Ford dealer, thats where I got mine. (take a old one with you as a sample)
Roy Nacewicz
Good to know. Not sure why I didn't think of checking with you for them. :o
Welcome to the barn.
