I need to replace the lower passenger door hinge on my 28 roadster. I can't seem to be able to remove the screws no matter what I do. Any ideas would be helpful. So far I have WD 40 them with no results. I really don't want to drill them out.
Grind your bit to fit the slot with flats along the sides, not tapered. WD-40, the normal stuff is not penetrating fluid. Kroll works good too.
An impact driver works good also.
