Trapdoor2
I said in another thread that I could not get the RH (passenger side) upper door hinge pin out of my '31 Coupe (I'm installing mirrors). I was advised to make or purchase a hinge pin removal tool. I bought the one Snyder's sells.
This thing looks very robust. 1/2" bolts, hardened pins of different lengths, thick bars. Frankly, it looks like overkill to me. The driver's side pin came out with a pin punch and a little minor tapping. No such luck with the passenger side. Surely this honkin' tool will pop it right out...
Now the hinge pin tool has arrived and following the instructions, I lubed up the threads. I added some layers of masking tape to the contact surfaces in order to protect the paint on the hinge. Spritzed the pin with WD-40 and gave it a couple days to sink in.
Great googly-moogly! That hinge pin must be welded in place. I have to be putting 100ft/lbs of torque on the bolts (takes a 3/4" wrench)...and the pin has moved barely 1/8"...the locking knurl is showing under the head of the pin. I draped the door with protective rags, cranked down on the tool and took a 16oz Ball Pein hammer to the bottom of the tool...shock wave therapy. All my air hammers and rivet guns are long gone...might have to visit Harbor Freight again.
It moved another 0.03".
I sprayed it down with more WD-40 and left it to soak overnight tonight.
In the meantime, I have started removing the distributor. It is working fine...but it looks pitifully dry and dusty. I don't think it has been serviced in a very long time...and it appears all original. Pulling it out of the head/block just confirmed my suspicions...the shaft is rusty, the set screw in the block is rusty. The cam is dry and worn. The points have carbon on them. It has the original upper shaft and screw (undrilled). The side oiler is bone dry.
Fortunately, I just received a drilled shaft and screw. I just didn't think to order a new cam or points. The bushings appear to be in good shape, but I'll do the various checks on the bench tomorrow before I get another parts order on the way.
