Russ, I’m having a problem aligning the driver’s side door. I’ve shimmed at the mid-body location at the back of the door and tightened the bolt. I’ve tightened the cowl bolts and now I have a door that still not closing, but is also not lined up. The back of the door is lower than the body by an inch, and I can’t figure out how to raise it without doing some major damage somewhere. Any and all ideas are welcome. Thanks!
I would take it all loose, lift the body a bit and slip in a couple thick shims under the body at the #2&3 bolt location on the drivers side. Then insert and fully tighten all bolts and measure the change in position at the back of the door. That would get you started.
Bodies are pretty flexible so I would not worry about doing damage.
