bambooboy
driver door sag,finally getting to it today.looks like new cowl posts were not drilled on front edge.will not be able to tilt& shim until I drill holes.looks like i'll need a long bit& have to drill on an angle from underneath. 3/8" bolt, hex or carriage?i'm using a bottle jack on plywood on running board under bottom hindge with sissors jack on underside to raise cowl,see any problems. thanks
