Tom Wesenberg
Here are 2 pictures of the tool that Don Turley designed and built to remove a stuck venturi. I will have to copy and paste the body of the email that Don sent me, to give you the dimensions. This is just like the tool I planned to make someday, but thanks to Don, I won't have to reinvent the wheel.
Hi Tom,
Attached to this email are photos of the very simple tool that I made to remove a broken venturi from the bottom half of a Zenith Model A carburetor.
The body of the tool is a piece of 1-1/2" inside diameter pipe or tubing x 1-3/4" long. The ends of this piece of pipe are faced so that they are square to the axis of the pipe. On top of the piece of pipe is a piece of 1-3/4" diameter steel bar, 1/2" thick with a 17/32" hole drilled in the center. This piece is welded to the top of the pipe.
The puller plate is 1/2" thick with a 1/2" NF thread in the center. The large diameter is 1.182". The small diameter is 3/4". Shoulder is 1/4" thick.
The bolt is 1/2" NF x 3-1/2" long. If you can not easily obtain a NF bolt, then I guess a NC one would work, but just make sure the thread in the puller plate matches the bolt.
You have permission to post or publish the photos and details, if you so wish. If you do, please credit the source as Don Turley. Thanks.
With the exception of my cell phone number, you can find all of my contact information on my web site, www.donturley.com
