KeeKeeBoy46
Regarding the two dome lamps installed in the B pillars of a 4 Door Sedan Deluxe, how do you remove the translucent plastic lens without damage in order to replace the bulb ? Thank you ! Kenny C.
If there is no screw in the bezel (need to know year of car) then simply pry the metal bezel off. The lens will stay with the bezel. Do not attempt to remove the lens by itself.
