If you are trying to eliminate the endemic drive train vibration between 36 and 39 MPH, good luck. No matter what you do to that three-main bearing crankshaft and flywheel/pressure plate, the Model A's four cylinder engine has an inherent vibration between those speeds, give or take one or two MPHs. Those engines have been that way since they left the factory and the vibration is just part of the Model A personality. By careful balancing and matching parts (maybe even adding a harmonic vibration dampener to the pulley), you might be able to lessen the vibration or move the vibration range up or down, but because of the whipping effect of the three-main bearing crankshaft with the center main as the fulcrum point, I doubt you will be able to completely eliminate that RPM vibration.
I wonder if the Burtz five-main bearing crankshaft has eliminated this vibration range? If anything can do it, a five-main bearing crankshaft ought to do the job!
Marshall
