Does anyone know what rearend might be?
skiddy8619
New member
I had bought this off an older farmer, he used it for a generator trailer/cart. It is very similar to the 9" but the third member yolk is on the opposite side? Thanks in advance.
Looks like all you have to do is flip it over and its correct. Pic too small for any identifying marks.
flip over, if you need box wrench onbottom bolt,its a8", if you can use a speed handle and socket its a 9"
It doesn't look like either an 8" or 9" because there isn't a removeable pinion bearing retainer. Also it appears the third member is round shaped, no flats on the top and bottom like an 8" & 9". Looks like it came from a 49 to 56 Ford sedan
