The Badger
I have a 239 CID German made truck engine. Under the intake manifold the block is mark S99T and four digits blocked with stars. As it usually is on this type of Ford engine. But, someone has grinded out the old engine number and put on a new. So the S99T is false! I believe that the engine earliest is from 1942-43. At that time they started the production of the 239 CID in Cologne (Köln) says Thilo M. I have been in contact with him. Other engine details is:
Rear mounted distributor drive.
Thin sleeves installed in all cylinders.
The heads are marked 99T.
The water holes between 2 and 3 cylinders on each side are 3 big trapezoid ones.
The intake manifold mounting surface is flat.
In the cast, on top of the bellhousing is the letter H. Take a look at the picture!
Can someone explain what the H letter means?
There are no other letters or figures at the bellhousing.
Regards
Carl
Regards
Carl
