philcobill
My special coupe just sprung a rear main oil leak. Do I panic, or just keep oil in it as I drive the car?
Bill Harms
Walworth, New York.
Bill Harms
Walworth, New York.
Sometimes it is the front, and it trails back as you travel down the road. Wipe everything clean, push it onto clean pavement, start it up and slide under it.
From there you can assess. How many miles on engine? lightened flywheel? I take it that it leaked zero before? Are you a member of a local Model-A club chapter?
Is it leaking a 1" puddle or a 6" puddle? If a 1" puddle, that is normal. If a 6"puddle and it happened suddenly and is coming from the rear of the engine, the rear main babbit bearing has probably cratered and you need an engine rebuilt.
Or could just be over filled with oil. Make sure the dip stick is all the way in and check the level. Oil spreads, so a small puddle can turn into a large one fairly fast.
I have a drip pan under the radiator, the transmission/engine (big pan) and one under the rear. I drive the car very often and enjoy it. I've driven from NJ to Gettyburg in 2017...JUST DRIVE IT. Check the fluids and enjoy it. I may suggest a lot of folks here use Valvoline 20/50 Racing Oil ($8.00 a quart). The higher viscosity when hot may help. They all leak, until they are empty. What are you going to rebuild an engine to put 1,000 miles on it.....fill it up it's cheaper and just fine. One last point you should wipe it all down and start checking bolts, my valve cover was leaking pretty good and so was the oil pan. Watch those oil pan bolts, very weak...not much pressure please or snap. Check all the rear banjo bolts they then to loosen around the area of the driveshaft. Relax man you finally got it drivable....drive.
